I can`t modify Wifi SSID Settings
ticsystems
ticsystems Posts: 86 image  ZCNE Certified
First Answer First Comment Friend Collector Sixth Anniversary
In this organization I cannot modify the Wi-Fi SSID Settings.
Yesterday I could modify without problems and today I can't.
From the android app yes I can.
It just happens to me with this organization that I am the owner.
  • Zyxel_Kay
    edited December 2023 Answer ✓
    Hi @ticsystems ,
    To assist you more effectively, could you enable Zyxel Support and provide your organization/site name? This will allow us to directly examine your site's settings for a detailed investigation.
    Currently, we've noticed an issue with SSID profiles not appearing on the Wi-Fi settings page in the Nebula portal for sites utilizing the USG FLEX H model. If your site employs this model, this might explain the discrepancy between the Nebula Control Center (website) and the Nebula App.
    We're working on resolving this in an upcoming Nebula system update. In the meantime, for any urgent SSID updates or modifications, please use the Nebula Mobile App.
    Thank you for your understanding and cooperation.
    Kay
  • Zyxel_Kay
    Hi @ticsystems ,
    Kay
  • ticsystems
    Yeah. I have a USG Flex 700H...
  • Zyxel_Kay
    Hi @ticsystems
    The bug has been fixed, and you can now configure your SSID settings as usual.
    If you have any more questions or need further assistance, feel free to reach out.
    Kay
Nebula Tips & Tricks
