Smarthome use GS1900-24E = Impossible .... 😤
I did say don't connect anything to the switch other then your PC with a fixed IP of 192.168.1.2 as in don't connect Starlink don't connect switch to internet then connect to 192.168.1.1
Peter ….. you might have attitude problem that isn't good
sorry you feel that way😓
Hi @QTT1,
Have you followed the guide I provided previously? Are there any problems that need help after you follow the guide?
Zyxel Melen0 -
Back home again …. still no with wifi or with out those addresses cant be accesed …
Only the computer:
12th Gen Intel(R) Core(TM) i5-12400F 2.50 GHz
64-bit, x64-suoritin
Windows 11 Home version 23H2
and your device connected via ethernet cabel…..
Please advise?
Hi @QTT1,
To help you solve this issue, could you provide a remote for me to check? Please provide me with the AnyDesk ID, AnyDesk access password with full privilege, and the Windows PC's password (if it needs a password to log in) for the remote. I will access it to help you find the GS1900 and check.
Zyxel Melen0 -
Hi Melen,
Ok thanks finaly.
what’s your business hours ?0 -
Morning,
where did you sent it ?
Hi @QTT1,
After remote, I have helped you to make sure your GS1900 is working with your smart hubs. Please keep monitoring if there are any problems. Happy new year to you and your family!
Zyxel Melen0
- 221 Nebula Ideas
- 612 USG FLEX H Series
- 53 Wireless Ideas
- 483 News and Release
