NR7101 Supervisor Password
CodIsAFish
CodIsAFish Posts: 3 image  Freshman Member
edited January 2024 in Mobile Broadband
I am looking to get the supervisor password for my NR7101 - I have used the generator floating about on the internet, but at appears not to agree with my device on the password.
The password is consistently refused, with username "supervisor" and "root" on the web/ssh/telnet interfaces, with both the new or old algorithm.
The device was bought from ebuyer in the UK in November 2021.
Looking at other threads it appears that the supervisor username can be changed in certain instances (ie, ISP does it), but I bought my device outright, so this should not apply.
Firmware is V1.00(ABUV.6)C0.
  • monstrmprz
    monstrmprz Posts: 37 image  Freshman Member
    First Answer First Comment Friend Collector Third Anniversary
    Hey,
    Try doing a factory reset: press and hold the reset button for 15 seconds
    Wait until the device reboots and you can reach the device again
    My NR7101's default login is:
    admin
    1234
    (The password is also on the back of the router)
    But how do you know the software version if you can't access the device?
  • SELBERG
    SELBERG Posts: 373 image  Master Member
    5 Answers First Comment Friend Collector Fourth Anniversary
    edited November 2022
    Command Prompt, type ipconfig and hit Enter.
    Maybe 192.168.2.1 shows up as default gateway!
    For some reason this sometimes pops up for me and I can't log in but a 1 minute power off fixes it.
  • CodIsAFish
    Hi Guys,
    Thanks for your responses, but I was looking for the "supervisor" password specifically - this is an additional account with a higher level of access than the standard "admin" account (ie, can get a shell on SSH).
    In the end, I ended up opening up the device and attaching a serial adapter to the headers inside, and dumping the flash and extracting the key as described here: https://th0mas.nl/2020/03/26/getting-root-on-a-zyxel-vmg8825-t50-router/#tangent-1-the-_encrypt_-algorithm
    My goal of custom-scripting AT commands in order to get SMS on this device (my provider insists on using SMS for 2FA for the billing on this account) is now a step closer :)
  • mas_mahmoudi
    mas_mahmoudi Posts: 1 image  Freshman Member
    Let me have the serial numbers of the modem. I will reply you with supervisor/root password as you are asking.
  • sviykaz
    sviykaz Posts: 11
    edited July 2023
    Any chance to get the admin password from the modem serial number for an LTE7490-M904? My device is stuck after a firmware update and the pwd on the label is no longer functional. BTW, modem S/N is as follows: S210Z14014277 (and no, VMG8825-B50B generator does not work).
    Best - S.
  • david454
    david454 Posts: 3 image  Freshman Member
    Hi, I bought NR7103 and password on label doest work, and I reset it but no changes, can I send you S/N of modem and you get me supervisor password please? This is realy heleped me.
    David.
  • liquidbydesign
    liquidbydesign Posts: 5 image  Freshman Member
    Hi!
    I would also like supervisor/root password for my Zyxel NR5103E.
    My serial number is S220Z37003127
  • matsby
    matsby Posts: 2 image  Freshman Member
    Hi!
    My serial number is S210Z26000338
    Thank you :)
