VoIP config on EX3301-T0
How can I set up VoIP SIP accounts on a EX3301-T0?
The manual only talks about checking the status via System Monitor>VoIP Status, and I cannot even find that.
What to do?
I bought it used, so it may well be a device that has come from an ISP.
Creating a new admin user didn't make any difference, but erasing the ROM-D and data partitions via the CLI did. After a reboot the VoIP menu is showing on my EX3301-T0. Thanks for your suggestions.
I think when you log into the device, you can find the VoIP settings in the menu.
You have to log in as admin not as user - did you ?
You are shure to have the EX3301-TO device with Voip and two green phone ports on the back ?
Or the EX3300-T1 device without such Voip phone ports for splitter telephony use ?
Hi @Peter2
Thanks for chiming in:)
Yes, it is a EX3301-T0 (label says so), and it has two green phone ports and a blue ethernet wan port. I log in with the admin account and password from the label on the back. VoIP settings did not appear after a firmware upgrade and factory reset.
I found no obvious voice or VoIP section in the configuration backup file.
So may be you have a special ISP version and some Menu points are disabled . The ISP configures VoIP and you cannot even see the config . May be you dont know your own sip data too .
But if VoIP functions correct it might be ok - VoIP config is rather complicated with many possible options there and so everything is configured ok in sense of ISP .
What happens when you create an new admin account ?
This was interesting , i looked too and another solution might be only to disable "modelcheck" and "fwidcheck" for normal firmware upgrade ….
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
