VoIP config on EX3301-T0
rh43
rh43 Posts: 8
edited January 2024 in Home Router
How can I set up VoIP SIP accounts on a EX3301-T0?
The manual only talks about checking the status via System Monitor>VoIP Status, and I cannot even find that.
What to do?
  • rh43
    rh43 Posts: 8
    edited January 2024 Answer ✓
    I bought it used, so it may well be a device that has come from an ISP.
    Creating a new admin user didn't make any difference, but erasing the ROM-D and data partitions via the CLI did. After a reboot the VoIP menu is showing on my EX3301-T0. Thanks for your suggestions.
  • Liba
    Liba Posts: 212 image  Master Member
    First Comment First Answer Third Anniversary
    I think when you log into the device, you can find the VoIP settings in the menu.
  • rh43
    rh43 Posts: 8
    Thank you for your suggestion, @Liba.
    There are no visible VoIP settings in the menu between Security and System Monitor on my EX3301-T0, running Firmware Version V5.50(ABVY.4)C0. How can I find it or enable it in the GUI?
  • Peter2
    Peter2 Posts: 176 image  Master Member
    edited January 2024
    You have to log in as admin not as user - did you ?
    You are shure to have the EX3301-TO device with Voip and two green phone ports on the back ?
    Or the EX3300-T1 device without such Voip phone ports for splitter telephony use ?
  • rh43
    rh43 Posts: 8
    Hi @Peter2
    Thanks for chiming in:)
    Yes, it is a EX3301-T0 (label says so), and it has two green phone ports and a blue ethernet wan port. I log in with the admin account and password from the label on the back. VoIP settings did not appear after a firmware upgrade and factory reset.
    I found no obvious voice or VoIP section in the configuration backup file.
  • Peter2
    So may be you have a special ISP version and some Menu points are disabled . The ISP configures VoIP and you cannot even see the config . May be you dont know your own sip data too .
    But if VoIP functions correct it might be ok - VoIP config is rather complicated with many possible options there and so everything is configured ok in sense of ISP .
    What happens when you create an new admin account ?
  • rh43
    rh43 Posts: 8
  • Peter2
    edited January 2024
    This was interesting , i looked too and another solution might be only to disable "modelcheck" and "fwidcheck" for normal firmware upgrade ….
