LTE 3302 SSH permission denied (pubkey)
Could do with some assistance to get SSH up and running on my LTE3302. I've activated remote management and SSH keeping the ssh port on 22. When I try to ssh using root@192.168.x.x I get as far as verification of the RSA key, but then receive a permission denied status due to pubkey authentication see last line in screenshot.
Bearing in mind there doesn't appear to be any access to add or amend keys in the GUI and telnet also appears not to work. Any suggestions on what I might be doing wrong?
FYI, I have the modem router in bridge mode and WiFi disabled.
Should also add that the reason I'm trying to do this is to have a Home Assistant automation to be able to restart the modem remotely if it needs a refresh of IP. Can't do this though without having access to SSH to reboot.
Hello @al_ross
Happy New Year.
Welcome to the forum.
Can you please tell us which model of LTE3302 you have and which firmware version?
- It will help us all find the right manuals and information to assist you.
Kind regards,
Tony
Hi Tony
Happy new year to you too.
It's an LTE3302-M432
I've pasted the firmware details below for reference
Hi @al_ross
You're welcome.
I have searched the Zyxel download library at https://www.zyxel.com/global/en/support/download?model=lte3302-m432
According to the user guide at from 2017, it appears that the device does not support SSH for remote management.
Only HTTPS and HTTP it seems.
Have you got some web config screenshots you can show please?
Kind regards,
Tony
You're right, it doesn't in the manual, but it does on the GUI. Please see below. The SSH option is visible in the remote management section. I'm wondering if the firmware was updated but the manual wasn't. When I run Nmap in Linux terminal I do get an open port for SSH though.
- 603 USG FLEX H Series
- 481 News and Release
