Router going off and on every 15 minutes
Simosims
Simosims Posts: 1 image  Freshman Member
Hi.
My router, ever since the software upgrade, keeps going off and on every 15 minutes or so.
I've done a master reset twice now, and still does the same.
Any ideas guys?
Model NWA50AX
FIRMWARE V6. 29(AByw. 1)
I've checked all wires ect, so no idea.
  • Zyxel_Nami
    Zyxel_Nami Posts: 659
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    image  Zyxel Employee
    Hello @Simosims
    Thank you for reaching us about your issue on NWA50AX.
    To help troubleshoot your problem, I would like to ask you to clarify a few details:
    1. When you say that "keeps going off and on every 15 minutes or so" are you referring to the NWA50AX reboots automatically or it is online and offline every 15 minutes on Nebula?
    2. Please ensure that you are using the correct power adapter for the NWA50AX.
    3. Could you please provide the event log from the Nebula for the time when the issue occurred? This may help us identify any error messages or events that could be causing your NWA50AX goes off and on.
    Alternatively, if you're managing the NWA50AX in Nebula mode, please enable Zyxel Support in the Nebula CC >> Help center >> Support request for us to check the issue.
    Best Regards,
    Nami
    Nami
  • AndyFish
    Hello, I am having the same type of issue, I have two NWA50AX and a NWA50AX PRO all doing the same issues. That they will show online and then offline and online again on Nebula, the NWA50AX are both POE and the NWA50AX PRO is using the correct supplied power adopter.
    I have checked and tried many solutions but still an issue, I am thinking is there a Nebula configuration issue?
  • Zyxel_Nami
    Hello @AndyFish
    Please keep the discussion on the following post:
    Nami
Nebula Tips & Tricks
