GS1200-8 managed switch with Ubiquiti AP
Hello @pkarthikkn
After switching to "load balance", have you noticed any improvement?
If i don't connect the 1st port to my LAN on pfsense, there is no internet available
⇒ When you unplugged the LAN connection (from the pfSense router's LAN port to port 1 on the switch), did you also remove VLAN 1 from LAG2? If so, losing internet on VLAN 1 would be expected. Our earlier suggestion of removing VLAN 1 from LAG2 was intended to allow both LAN and LAG connections to coexist without conflict.
Feel free to keep us posted if you have further problem.
Nami
I didn't removed the LAGG, just the LAN. But I'm not getting the internet. Sorry for the late reply, I was busy and went out of country for few days. Will keep trying
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 492 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 47 Wireless Ideas
- 285 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
