NR7101 slow WAN speeds
Hi everyone.
I have bought an NR7101 few weeks ago as a replacement for a Tenda 5G03. Unfortunately the results are quite disappointing and I can't figure out what's wrong.
Today I've collected some data that I would like to share with you, hoping to get better speeds with this router.
I live in Italy and I have a Wind SIM inside the router. My house 300m from the BTS which I can clearly see from my roof and as you can see from the photo, the router is pointed directly towards it.
My bands look good and I can connect to all the available ones on that BTS:
LTE 20, 7, 1
5G 3
The signal strength is obviously great:
So far so good but here it's starting to get weird.
Using the sim within my iPhone, from the roof, pointing towards the BTS, these are the speeds I can get. This is basically the top speed available on the BTS with Wind:
iOS field test confirms I'm getting the same bands connected with the NR7101.
With the NR7101 I can't get my download speeed over 90Mbps and upload speed over 50Mbps.
With my previous indoor router Tenda 5G03 I could easily get speeds around 160-180Mbps, I can't understand why the NR7101 which should be much more powerful and installed in a much better position provides such bad results.
Last piece of information, this is the firmware and modem FW I'm using.
Current Firmware Version: 1.00(ABUV.8)C0
Current LTE Module Version: RG502QEAAAR13A02M4G
I hope someone could help me.
Thank you
Best Answers
Your LAN speed is?
Well, now I feel dumb…
But I can't understand why is that, I am connected to the router directly with my laptop which is equipped with a gigabit eth adapter:
https://www.intel.com/content/www/us/en/products/sku/82186/intel-ethernet-connection-i219v/specifications.html
Using the original POE adapter included into the NR7101 box. Is there a way I can force the gigabit LAN on the router settings?
Thanks again.
I had the same on my connection from the beginning.
It was due to a bad ethernet cable between the modem and the adapter.
- 1. Uncheck B20 and check speedtest.
- 2. Select only 4G and re add B20 and check speedtest again.
Thanks Selberg. Here's the result. Pretty much unvaried…
1.
2.
Your LAN speed is?
Thanks again.
Thank you Selberg, I will try to change the cable in the next few days as that will be a tricky job :(
This was helpful thanks!
My suggestion is that you take down your modem and connect a short ethernet cable to see if it changes to 1000m/full before you change the cable.
Replaced the cable with a CAT7 external cable. That is more like it.
Thank you for your valuable help!
I believe we can close the issue :)
2
- 433 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 116 Nebula Status and Incidents
- 6K Security
- 389 USG FLEX H Series
- 295 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 4K FAQ
- 83 Security Highlight
