Zyxel VMG3925-B10C Firmware Upgrade
I want to upgrade the firmware on my VMG3925-B10C router. The older firmware version is V5.13(AAVF.10)X4 and I want to upgrade it to V5.13(AAVF.18)C0.
I followed the instructions however "Firmware Upgrade" option is available in the "Maintenance" menu, I have also attached the screenshot of that interface please help me in this regard upgrading my firmware as soon as possible. Thanks
Best Regards,
Usman
I think you need to use the "admin" account to log in to the device. If you still don't see the "Firmware Upgrade" option, you may need to contact your ISP or retailer for help.
Hi Liba, thanks for your response.
I logged in using the "admin account", I put the "username" as "admin" and the "admin Password" which is mentioned on the backside of my device, but it didn't work for me I also reset the router many times but it also didn't work for me.
My Internet Service Provider also tried to do it and he also ended up with no result.
So can you please tell me any other method to flash its firmware? I also searched for alternate methods on the internet but didn't find any useful method.
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
