NAS326 - no application list in App Center
I get a new NAS326 - Firmware version V5.21(AAZF.15)
The list for "all Apps" is empty and I tried to update it, but nothing happen. Internet access is working, ping to google is working.
Out from this disscussion
the ping to ftp2.zyxel.com doesn't work, also from my PC.
  • suisei
    suisei Posts: 120 image  Ally Member
    First Comment First Answer Friend Collector Second Anniversary
    The solution is on page1
    "After a long search on forum and some try and try again I create the folder 'zy-pkgs'.
    \\NAS_IP\admin\zy-pkgs\           (NAS_IP -> ex: 192.168.1.100)
    Then put a file named 'web_prefix' with 'ftp://ftp2.zyxel.com/' text inside (that's a txt file but must not have that extension on the nas folder).
    Then all works on App Center and the ZyxelCloud is now working."
    You can give it a try.
    I think the server is not able to respond the reuqests, I cannot ping the server, too.
    You can check by using cmd to and type nslookup to see if your network could parse the domain.
  • Thank you for your reply, I already tried this, but the app center is not updating.
  • alexolivan
    alexolivan Posts: 2 image  Freshman Member
    Hi communtity!
    2025 I'm on the same boat:
    I got a fully working NAS326 but I see there's no applications anymore… very sad, since the device is working fine. I upgraded firmware to latest and it overall looks good!!! but I found it comes with no NFS support out-of-the box (A Linux based NAS featuring iSCSI, but no NFS? kinda weird to me) …anyways: it seems zyxel has wiped out the ftp servers with zpks in the mean time.
    Has anyone a clue on how to get those zpks and install them?
    Cheers.
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    Here you can find a backup of the package server. It seems you can install them by copying it in \\admin\zy-pkgs.
    If that fails, you could install MetaRepository, and add the package server backup as repository.
