GS1350- CLV not working
I have a new to me GS1350-6HP. Its running the latet 4.70 firmware as far as I can tell. Finding it very difficult to get the vlans doing what I want and am at the CLI trying to enable CLV mode (I am very familiar with cisco switches).
The CLI guide for the 1350 says I should be able to enable, config, clv to enter clv mode. I get an invalid command? What am I missing?
GS1350# enable
Password:
GS1350# config
GS1350(config)# clv
%Invalid command "clv"
GS1350(config)#
Best Answers
Thanks for the help in the related post which solved the config query.
OK, well it would be good if the GS1350 CLI guide was renamed as a generic document. Its named as for the GS1350 (GS1350-26HP_V4.70_Ed2.pdf)
and I followed the GS1350 link
Perhaps you could help me translate. In cisco world what I am trying to do is
define a MAC group
Cisco(config)#vlan database
Cisco(config-vlan)#map mac 00:1d:c1:00:00:00 24 macs-group 1
which I believe translates to
vendor-id-based-vlan name "" source-mac 00:1d:c1:00:00:00 mask ff:ff:ff:00:00:00 vlan 400 priority 3
I am not sure what I need to do for the VLANs and port settings.
In cisco, I would define the Vlans and the port settings I am trying (unsuccessfully so far) to replicate are
Cisco(config-if-range)#int range ge5-6
Cisco(config-if-range)#switchport mode general
Cisco(config-if-range)#switchport general allowed vlan add 100,400 untagged
Cisco(config-if-range)#switchport general map macs-group 1 vlan 400
Cisco(config-if-range)#switchport general pvid 100
Hi @dazey77,
Please reference the new post you created. I leave the configuration in that post.
Zyxel Melen0 -
- 440 Beta Program
- 291 Service & License
- 4.6K FAQ
