Delete accounts
Hi. I tried to set up my new FWA510 and I had problems as I find your describtions a bit unlogic compared to eg. Huawei.
So in a bit of panic I tried to set up 3 accounts to my 3 mailaddresses to se wether I could change access password, network name and wifi password etc.
But everything needs to be erased so I can start from scratch again.
Can you please erase my 3 accounts related to the 3 email addresses (I assume you need the other two in a seperate email)?
I will the reset the router and start from beginning again.
As I( understand your descriptions I can then set up everything from my PC - create a new account and then configure my login password, then register the router and then set up wifi network network and password in the CC.
Is that correct?
Rgds
Hi @Christian_Berg1 ,
You can privately send the three email addresses you used for testing via a private message (Click to my account and select 'Message'). We will assist you delete them from Nebula.
At the time of this writing, Nebula supports configuring most features of Security Appliances, Switches, and Access Points. Regarding the FWA510 mobile router, Nebula provides IP Passthrough/Router mode configuration, LAN IP address, DHCP on/off, the ability to schedule firmware upgrades or set them to auto-upgrade and monitor your network at any place as well. For other configurations, please access the local WEB GUI. The method to access mobile router WEB GUI here:
In Router mode: [Mobile router] How to access the local GUI in Router mode? — Zyxel Community
In IP passthrough mode (bridge mode): [Mobile router] How to access the local GUI in IP passthrough mode? — Zyxel Community
Zyxel_Judy
Zyxel_Judy
Hi there,
I've noted that you've sent us three email addresses, and it appears you'd like to maintain one of them specifically for using the Nebula service. To facilitate this, please let us know which email address you wish to retain for Nebula access. We'll make sure that this email is preserved for your seamless usage of Nebula and two others will be deleted.
Zyxel_Judy
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 125 Nebula Status and Incidents
- 6.3K Security
- 488 USG FLEX H Series
- 322 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 455 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 95 Security Highlight
