Firmware Update Request for Second-hand Zyxel NR5103E Router
Dear Community,
I had the same problem as well. Bought a NR5103E second-hand with firmware B12 in may 2023 and use it in Germany. I couldn´t find a newer firmware anywhere. The online-update function on my NR5103E never showed a newer version.
Today after I didn´t try to find a Firmware Update for some weeks, I checked the online update function and what should I say! It showed the newer Version B15. I installed it and the router runs fine on it so far.
Maybe Zyxel heared our prays…
Are there any other users that got the new Firmware that way?
Regards.
I got it two weeks ago
Some problems have been solved
But there are errors that have not been resolved yet
5G does not connect if it is band N40
5g if band n41 works with b3 only Cannot connect to both 2ca n78/n40
- 434 Beta Program
- 2.6K Nebula
- 172 Nebula Ideas
- 404 USG FLEX H Series
- 296 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 4K FAQ
- 83 Security Highlight
