NBG7510 Firmware Update not found or impossible?
#tonygibbs16
And you also updated from V1.00(ABZY.1)C0 or later ?
Yes I did Peter2.
It went to .3 when I bought it from .1, and .6 last month.
Kind regards Tony
Did some reverse engineering of the ZySH commands:
I found the "zycli" command is working via SSH. Just typing "zycli" prints a list of valid comands. For example, you can output the firmware version via "zycli swversion show".
"history" prints a command history.
"ifconfig" prints the network interface configuration.
"sys" prints some system configuration stuff that I didn't unserstood until now.
"exit" close ssh session.
"cfg" prints several configuration options (e.g., "cfg lan get").
"ping 192.168.1.1" ping another host
"tcpdump" very interesting but unfortunately only outputs "/bin/sh: tcpdump: not found".
"traceroute www.somedomain.com" prints an route trace.
"?" will print a help page with all commands.
One can do this trial and error stuff by typing a random letter (e.g., "c") and pressing the tab key for auto complete. That was how I started until I discovered the "?" command.
Some commands seem to need higher privileges, so the "admin" user is not god on the router. Google told me there are a root and supervisor user on Zyxel devices as well.
Well so far I didn't found a posibility to upgrade the firmware via the SSH interface.
Honestly, I guess it would be easier to setup a custom made access point with an Rasberry Pi and standard Linux OS than spending all my time with this crappy device :-/
Your choice @SHA512 as you have the skills.
At least the firmware upgrade is not impossible, because there is a workaround.
* even though that workaround is not easy.
* and the workaround involves the NBG7510 having a route to the Internet and being in router mode.
Kind regards,
Tony
Perhaps it is a question of ports have to be reachable ? Port 443 HTTPS and 80 HTTP for example maybe they have to be enabled for remote management from WAN ?
Firewall ingoing and outgoing traffic allowed ?
But not everyone has a public IPv4 adress ….
Hi @Peter2
For your information, I have not had to enable either of port 80 or port 443 remote management from WAN in order for my NBG7510 to download firmware upgrade when in Router Mode.
Kind regards,
Tony
If there is no information which connection is used and perhaps requirers open ports one should try out common things like opening firewall or declare the device as DMZ .
Offering firmware download enabeling to install it via webgui would be the best solution for such a router mostly used in second line .
Maybe @Peter2 firmware download would be good…but it is not there today, and Zyxel might not want to offer it on the NBG7510 model.
- especially since browsers like Chrome and Edge have blocked the insecure FTP protocol from working in them.
I agree that there are no details about which ports are used by firmware upgrade to download new firmware.
- maybe the NBG7510 uses port 443 which many firewalls will be set-up already to allow outbound conversations on without additional configuration being required…
- I know that I did not need to make any firewall changes in the home router firewall that is between my NBG7510 and the Internet in order to do the firmware upgrade to the .6C0 release.
Kind regards,
Tony
Yes, i read it too somewhere there is no more ftp service only https .
here is a hint :
May be version 1 firmware still tries to connect via ftp and the failure dialogue is not informative ?
I tried with an old firefox version : ftp.zyxel.com is still reachable there are some older things but nothing for this device .
I doubt it @Peter2 since the FTP service was replaced by HTTPS for new devices by March 2021, which was before the NBG7510 was released in August 2022.
Kind regards Tony
- 441 Beta Program
- 209 Nebula Ideas
- 534 USG FLEX H Series
- 338 Security Ideas
- 51 Wireless Ideas
- 295 Service & License
- 461 News and Release
