Upgrade Firmware LTE5398-M904, not band 1 work
Magicszi
Magicszi Posts: 1 image  Freshman Member
edited January 2024 in Mobile Broadband
Hi, I updated the modem to version 12 of the LTE module (released by you). It no longer aggregates band 1 with the other bands, nor does it use only band 1 to navigate. I would like to downgrade to version 8, the one previously installed. Can you carry out the procedure remotely? Or can you possibly pass me the file to update manually?
I can no longer work with this modem, I tried to reset but the problem persists.
Model: LTE5398-M904
Installed version: EG18EAPAR01A12M4G
Previously installed version: EG18EAPAR01A08M4G
