DHCP Domain Name configuration
DaviD42
DaviD42 Posts: 10 image  Freshman Member
Where can I configure the DHCP domain name using nebula for a USG Flex 200?
Basically I need the Zyxel DHCP Server to populate the Connection-specific DNS Suffix with our local domain name.
Thanks for the help.
David
  • Zyxel_Jeff
    Zyxel_Jeff Posts: 1,368 image  Zyxel Employee
    100 Answers 500 Comments Friend Collector Fifth Anniversary
    edited January 2023 Answer ✓
    Hello @DaviD42
    Welcome to the Zyxel community. You cloud refer to the below steps for how to configure it:
    SETP1. Navigate to Firewall Configure > Interface LAN interface configuration and add a new DHCP option. I use the lan1 interface with IP address 192.168.88.1 for an example.
    Option chooses "User defined", Type chooses "TEXT" and type the data to Name, Code, Value fields.
    STEP3. Navigate to Firewall Configure > Firewall settings and add an Address record.
    STEP4. If the PC connects to lan1 interface(with IP address 192.168.88.1) and would find the Connection-specific DNS Suffix has already been added.
    Thanks.
  • Zyxel_Jeff
    Hello @DaviD42
    Thanks.
  • DaviD42
    Excellent. Thank you very much for your help.
  • Zyxel_Jeff
    Hi @DaviD42
    OK, you are welcome ;) !
  • networx
    networx Posts: 9 image  Freshman Member
    Dear,
    This option is missing for me. Please advise:
    USG FLEX 500H
    firmware V1.10(ABZH.0)
    DHCP Extended options is missing
  • networx
  • same here on FLEX 700H… any Update on this?
Nebula Tips & Tricks
