Multy M1 client not listed
Maxfilip
Maxfilip Posts: 2
edited March 2024 in Multy WiFi System
dear community,
I’m using a Multy M1 as wireless access point and one cabled client.
the cabled client is not visible in the client’s list (parental control). How is that possible? And how to make it visible?
thanks
  • Zyxel_Jerry
    Zyxel_Jerry Posts: 1,370  Zyxel Employee
    Hi @Maxfilip
    Are you using Bridge mode?
    In Bridge mode, the device will not be recorded in parental control.
    If you're in router mode, try to have the client ping the gateway of Multy M1 (default 192.168.212.1) and check again.
  • Maxfilip
    Maxfilip Posts: 2
    hi @Zyxel_Jerry
    thanks for the feedback
    I’m not using the bridge mode
    I pinged the gateway but still the client does not show
    thanks
  • Zyxel_Jerry
    Hi @Maxfilip
    Please help to send us the feedback, on the Multy APP.
    You can follow below steps to send the feedback on the Multy APP
    Describe your issue
