Necmettin Ersurekci
Hi @atyav
To better understand your issue, could you please enable Zyxel Support on your Nebula CC and provide your org and site name?
Kay
Hi Kay
I enabled the zyxel support The organization name is Aytav Site name is Aytav_Hendek
In fact My problem ıs I can not reach any switches config port. When I clicked The config port menu not opened any devices
Hi Kay.
Urgent actions had to be taken by the customer. We moved the switches on the site to a new site within the same organization, but the problem continued. We moved all the switches on the site to a new organization and the problem disappeared.
Hi @bymusty
Could you please enable Zyxel Support on your Nebula CC and provide your org and site name?
We will try to fix it from our backend system.
Sorry for any inconvenience caused.
Kay
As I mentioned above, the new organization works smoothly. We deleted the old site, but @aytav can give you a new site name in the old organization and you can control it. @aytav can you please help with this?
Thank you for the feedback.
As the issue seems to occur only under specific conditions, we would like to conduct further troubleshooting with your old organization. Since we currently couldn’t find the organization/site: Aytav / Aytav_Hendek at Zyxel Support, could you please re-enable Zyxel Support again and provide your organization and site name?
Additionally, if the issue reoccurs, please enable Zyxel Support on your Nebula CC and provide your organization and site name. We will promptly address it from our backend system.
Kay
We are Deleted all sties in Aytav_old organization However We can not delete Aytav old Organization. You can access Aytav_old organization Can You delete Aytav_old organization This is enough
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 924 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 213 Service & License
- 339 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 1K Nebula FAQ
- 446 Security FAQ
- 238 Switch FAQ
- 214 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 142 Service & License FAQ
- 74 About Community
- 62 Security Highlight
