Where can i see the real "Channel Width" used by a connected client
Hi @Chris888
Regarding your request about the feature of displaying the channel width that every client is using, I would like to suggest raising it as an idea:
To monitor and optimize the wireless performance, you can utilize the Wireless Health feature on our Nebula CC. For more detailed information about how the wireless health function works, please refer to this article:
Kay
Hi @Chris888
The channel width doesn’t appear on the clients list as it is more related to the AP radio setting.
The channel width is configurable for the AP radio. You may select the wireless channel bandwidth you want the AP to use at Nebula CC > Site-wide > Configure > Access points > Radio settings. To check which channel width on each band is being utilized by the AP, you may scroll to the bottom of the radio setting interface:
Kay
Hi Kay,
thanks a lot. I thought every client connect with his own channel width?
The settings on the AP are only max…?!?
I´am wrong?
Thanks! A lot of things change dynamically. From my perspective it is usefull to show it - as all the other values. Maybe an improvement in the next update?
Hi @Chris888
I believe achieving your requirement may pose some challenges. For the WiFi 6 standard and below, the actual channel width changes dynamically with each transmission due to the wireless network environment, rather than with each client/connection.
However, with the WiFi 7 standard, the actual channel width might remain unchanged. WiFi 7 incorporates a new technology called Preamble Puncturing. Its function is such that when the Access Point (AP) detects that certain channels are busy, it can skip these occupied channels without excessively reducing the channel width used.
To illustrate, consider the image: if today the AP operates on a bandwidth of 80MHz with the main channel set to 36. Previously, if channel 44 was deemed busy, the adjacent 40MHz band couldn't be utilized. However, in WiFi 7, channel 44 can simply be skipped, allowing for transmission using 36/40/48.
In another scenario, if channel 40 is detected as busy, traditionally the AP would reduce the channel width to 20MHz, significantly impacting transmission performance. But with this new technology, the AP can bypass channel 40, transmitting using 36/44/48 without such degradation.
Kay
Understand, but actual there is no way to see on which bandwidth a client would like to connect, call it the "maximum". I think it is important to see this…
Hi Kay, understand. From my perspective it is usefull/neccessary to find any client having problems looking on compability etc.
Maybe i´m wrong, but my last accesspoint show this details…
Hi @Chris888
Kay
Kay, thanks a lot!
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 923 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 212 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 1K Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 213 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 142 Service & License FAQ
- 72 About Community
- 62 Security Highlight
