Multy M1 client not listed
Maxfilip
dear community,
I’m using a Multy M1 as wireless access point and one cabled client.
the cabled client is not visible in the client’s list (parental control). How is that possible? And how to make it visible?
thanks
Hi @Maxfilip
Are you using Bridge mode?
In Bridge mode, the device will not be recorded in parental control.
If you're in router mode, try to have the client ping the gateway of Multy M1 (default 192.168.212.1) and check again.0 -
hi @Zyxel_Jerry
thanks for the feedbackI’m not using the bridge mode
I pinged the gateway but still the client does not show
thanks0 -
Hi @Maxfilip
Please help to send us the feedback, on the Multy APP.
You can follow below steps to send the feedback on the Multy APPDescribe your issue
- 415 Beta Program
- 2.4K Nebula
- 151 Nebula Ideas
- 98 Nebula Status and Incidents
- 5.7K Security
- 277 USG FLEX H Series
- 277 Security Ideas
- 1.4K Switch
- 74 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.4K Consumer Product
- 250 Service & License
- 395 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 75 Security Highlight
