USG40 problem VPN SecuExtender Tap-Windows Adapter V9
Good morning,
after the last firmware update to version 4.32 (AALA.0) C0 with SecuExtender client version 4.0.3.0 installed on windows 10, I encounter a client-side problem on the release of the IP to the Tap-Windows Adapter V9 adapter, as if a incorrect ip address. This causes the inability to enter the corporate network.
The only way is to manually configure the IPv4 in Tap-Windows Adapter V9
thank you
You have the same symptom as that in the following discussion.Workaround- Set subnet in "Assign IP Pool" and the issue is resolved.Solution- Wait for firmware 4.33.0
thank you, I will try immediately
- 215 Nebula Ideas
- 569 USG FLEX H Series
- 342 Security Ideas
- 295 Service & License
- 471 News and Release
