USG40 problem VPN SecuExtender Tap-Windows Adapter V9
Good morning,
after the last firmware update to version 4.32 (AALA.0) C0 with SecuExtender client version 4.0.3.0 installed on windows 10, I encounter a client-side problem on the release of the IP to the Tap-Windows Adapter V9 adapter, as if a incorrect ip address. This causes the inability to enter the corporate network.
The only way is to manually configure the IPv4 in Tap-Windows Adapter V9
thank you
You have the same symptom as that in the following discussion.Workaround- Set subnet in "Assign IP Pool" and the issue is resolved.Solution- Wait for firmware 4.33.0
thank you, I will try immediately
- 384 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 77 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 898 Nebula FAQ
- 415 Security FAQ
- 234 Switch FAQ
- 205 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
