many disconnects on NWE130BE based on Wifi 6E with Intel AX211
Chris888
Chris888 Posts: 69 image  Ally Member
First Comment Friend Collector Second Anniversary Community MVP
edited April 2024 in Nebula
I´m working now a few days with the new NWE130BE.
I see a lot of WLAN disconnections with my Windows-Laptop (using AX211 with latest driver and Win11) based on Wifi6E.
My Macs, Iphones, etc (all based on Wifi6, not 6E) work well.
A lot of messages like:
Station:
XXX disconnected by Intra Roaming on Channel: 40, SSID:
XXX, 5GHz, Signal: -65dBm, Download/Upload: 1.28MB/1.15MB, reason
5, Interface: wlan-2-1
Station:
XXX disconnected by STA reconnect on Channel: 69, SSID:
XXX, 6GHz, Signal: -65dBm, Download/Upload: 0 B/0 B, reason 8,
Interface: wlan-3-1
Every disconnect ends up in a reconnect of my AnyConnect-App. MS Teams is unusable etc….very frustrating.
Any idea is welcome!
Regards
Christian
PS: Opened a ticket…keep you informed
  • Chris888
    edited March 2024
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,344 image  Zyxel Employee
    Hi @Chris888 ,
    The logs indicate that the WLAN client (STA) determines whether to roam or reconnect, as this behavior is inherent to the STA. To optimize your network and minimize Wi-Fi disconnections or intermittent connectivity, please consult the following article:
    Zyxel_Judy
    Untitled Image
  • Chris888
    Hi Judy,
    thanks a lot. After testing your recomendations today, i see less disconnection, but still happen.
    But what helps:
    Switch "Transmit Power" from "max 30db" to "fix 29" in 5 & 6 GHz band.
    Bildschirmfoto 2024-03-27 um 17.06.30.png Bildschirmfoto 2024-03-27 um 17.07.17.png
    After this the connection was perfect without any further problems.
    I will test it a few more days…
  • Chris888
    i have done a few more testings over the last days.
    The result is allways the same. Without "fixing" the Transmit Power" i see disconnects etc.
    But only (!) on my 2x WLAN 6E-Devices (both witch an AX211). All other clients work well (but all of them are Wifi6 or less devices).
    I swap the AX211-Nic in one Laptop with a brandnew Intel BE200 (WiFi7).
    Driver is the same, Windows is Win11 - 2023H2.
    Working on Wifi7-Protocol, but connected on Wifi 6E, because Win11 did not support Wifi 7 in the moment.
    Problem stays the same.
    Any further Ideas?
    Christian
  • Chris888
    Today update firmware to 6.75 and update Intel Windows11 driver to 23.40.0.4
    Will test tomorrow….
  • Chris888
    edited April 2024
    After update, i changed WLAN-Seetings to "Auto" (Transmit Power).
    Today with new firmware and new driver: Only 1 Reconnect! Very stable connection over the day.
    I will change setting in windows driver "Roaming dynamic" from medium to medium-low. Testing next week.
    I´m happy to make steps forward.
    PS. Why changed someone the thread to "Nebula"? I think it points to WLAN.
  • Zyxel_Judy
    Hi @Chris888 ,
    Thank you for sharing your test results.
    Since your AP is managed by Nebula Cloud, we have moved your post to the appropriate category. The WLAN category is intended for discussions related to AP issues in Standalone mode. That will make it easier for users to find relevant discussions and solutions.
    Zyxel_Judy
    Untitled Image
  • Chris888
    after testing today i´m very happy.
    No more disconnects, no more reconnects. etc
    My solution:
    latest firmware 6.75
    latest Intel driver: 23.40
    Setting AP: standard (with smart steering, Chanel width 160&320, etc )
    Setting driver: Roaming dynamic" from medium to medium-low
    Thanks for your support
    Christian
Nebula Tips & Tricks
