zyxel 8-port 2.5g multi-gigabit unmanaged switch
Lefty_Insider
Lefty_Insider Posts: 28  Freshman Member
I have the following product: zyxel 8-port 2.5g multi-gigabit unmanaged switch for home entertainment or soho network
I use it in a network with a Hitron 2.5 Gbps cable modem, Netgear Nighthawk 2.5 Gbps router and this switch. I also have three 2.5 Gbps computers connected to this switch.
To get an IP address from with ISP modem with the router, I must connect it directly.
If I connect the modem port to the switch, and the switch to the router, it will not pass through the ISP IP address.
This is an unmanaged switch so why is this?
Thanks, Lefty
«13456
    PeterUK Posts: 3,537  Guru Member
    edited April 2024
    If you have done the following
    https://www.virginmediabusiness.co.uk/help-and-advice/products-and-services/hitron-router-guide/dynamic-modem-only-mode-user-guide/
    You only get one WAN IP by one source MAC if you connect the switch to the Hitron many devices each with its own MAC only one may work this is why you use NAT router.
  • Lefty_Insider
    I am using a Hitron EN251 which is just a modem. My temporary solution is to connect modem to router and boot router to get a ISP WAN IP.
    Then I connect modem to switch and switch to router. That way i have 2.5 Gbps on my network all the way to the modem which unfortunately, at least for now, has a Spectrum 1 Gbps limit. Router sends DHCP LAN addresses via the switch/router to the clients just fine.
    Works until I reboot the router and then I have to do this setup all over again. What happens is the system after router reboot sets the router to 10.0.0.2 (don't know where this IP comes from) for some unknown reason and I have to go back into the router and fix the IP.
    So I take it that you believe that it is the switch MAC (no PC's connected) that is interfering? Any ideas on how to work around this? Could a managed switch be configured to get around this?
    Thanks for your input,
    Lefty
    How many WAN IP's do you get from the modem?
  • Zyxel_Nami
    Zyxel_Nami Posts: 659  Zyxel Employee
    Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Security Zyxel Certified Network Administrator - Nebula Zyxel Certified Sales Associate
    edited April 2024
    Hi Lefty @Lefty_Insider
    Based on your description, it seems your intended setup is: Hiltron EN251 modem → Zyxel MG-108 switch → Netgear Nighthawk router, however, the Netgear router is not receiving the WAN IP in this setup. To address this issue, we would like to clarify a few points:
    • Router model: please provide the full model names of your Netgear Nighthawk router
    • Router connection: Could you confirm which port on the Netgear router the switch is connected to? Is it the WAN port or a LAN port?
    ⇒ Regarding this concern, MG-108 doesn't have the MAC address itself; it simply forwards packets based on observed MAC addresses.
    Nami
  • Lefty_Insider
    Sorry for the delay I was out of town.
    Spectrum will only give you one. I wonder if they would give me two with two port modem, or just the same one on each.
  • Lefty_Insider
    Nami,
    Router is a Netgear Nighthawk RAXE500 and am plugged into it's 2.5 Gbps port with a Cat 7 cable. Another Cat7 cable from the switch to the 2.5 port on the modem.
    Cat 6 cables (50 feet or so) from the MG-108 switch ports, when I connect them to the switch ports rather than the router ports, to another MG-108 in my office. Network status shows me 2.5 Gbps on my client computers.
    So the question remains, why won't the switch pass though the ISP WAN IP address?
    I thought that all network devices had a MAC address.
    Thanks, Lefty
    As you only have one WAN IP it be locked to one source MAC if you do
    Modem <> switch <> to two devices each with a different MAC only one will work this is why you do
    Modem <> router <> switch
    This allows the router to do NAT to take a 192.168.0.xxx to your one source MAC and WAN IP out the router
    other types of NAT's exist but they are not as simple and have limitations for one WAN IP on a single MAC
  • Lefty_Insider
    I am waiting for Nami to clarify his statement that the switch has no MAC, and that the switch cannot possibly be interfering.
    We shall see if he has a solution.
  • Zyxel_Nami
    Hi @Lefty_Insider
    We've conducted a test with a similar setup (ISP modem → MG-108 → USG FLEX 100 Firewall). The firewall successfully received the public WAN IP from the ISP. This confirms that the MG-108 can correctly forward packets based on the MAC addresses it learns.
    To understand better your setup and figure out the cause, let's clarify the following points:
    ⇒ Let's double-confirm the steps of your temporary solution:
    1. connect the WAN port of the router directly to the Hiltron modem, the router can obtain a WAN IP
    2. unplug the cable between the modem and the router
    3. connect the modem to the switch, then the switch to the WAN port of router
    ⇒ With this setup, does the router still receive the WAN IP before rebooting?
    After rebooting, the router receives an unknown IP, 10.0.0.2. On which interface does it receive the IP 10.0.0.2, LAN or WAN?
    ⇒ For clarity, could you confirm if the following accurately describes your current setup?
    And when you mention that the router can't receive the WAN IP, are you referring to this setup?
    Regarding the MAC address, you can verify by checking the label on the bottom of the MG-108 device; it does not display a MAC address, which is typical for an unmanaged switch. Unmanaged switches like the MG-108 do not manage IP addresses or MAC addresses; they simply forward Ethernet frames based on the MAC addresses they observe from incoming data on connected devices. This design ensures the unmanaged switch merely passes along data without modifying or managing it.
    Nami
