WiFi connection getting disconnected while roaming (Multy M1)
Dear Zyxel,
I have setup an M1 system with 1 master Mesh and 4 slaves. There is one Mesh slave where I go, the internet disconnects. Actually maybe it happens in some more areas, but in living room it happens most of the time.
I have setup 5G and 2.4G networks. I tried to use only 1 SSID before (one name and one pw) but it was worst, casued many disconnection.
Now when I moving in out house (roaming) to the living room, my iPhone disconnects and ask for password. When I try to enter again, it says not correct pw. After 2-5 minutes it will find the network and will join.
I have sent also sent a Feedback, so you will get all the log files I hope.
Please help to what should I do to be able to stabilise the connection?
Dear Support Team,
I did not received any answer to this issue either her nor in e-mail.
But I got e-mails that I should give feedback if the issue still exist.
Do you have any feedback?
Dom
———————————————————Dear Sir/Madam,
Thank you for contacting Zyxel support team.
We are waiting for your response of ticket#231100993, please email to us if you still have concern for this case. If there is no concern, then we will close this ticket.
Please note this ticket will be closed if we still don't get the response.
Please refer to the ticket information below.Ticket#
231100993
Subject
iOS: 17.1.1 (Ver:2.6.1.231012)
Requester
Product Model
WSM20
Hi @Domee
It seems you do not receive our email on 11/20
I have contacted you via email
Please check your mailbox.
Best Regards,
Jerry0 -
I have the same problem, mostly on Apple Devices. It disconnects and unable to reconnect and fails with wrong password. Need to reboot everytime it happens to reconnect and its inconvenient.
Hi @DreamVader
To address your issue effectively, could you kindly send feedback through the Multy APP when the problem occurs? Sending feedback via the app allows us to gather the log file from your device, enabling us to investigate and address your issue more efficiently.
For guidance on submitting feedback through the Multy APP, please refer to the following link:
Kay
the error still exists. You can also reproduce it by switching from 'WPA3 Mix' to 'WPA2' in the WLAN settings. Cell phone can no longer log in. Both Apple and Android. You have to remove the network from the cell phone and set it up again, then it will connect again.
I use latest Firmware V1.00(ABZF.6)C0
Hi @Andreas_K
To better assist you, could you please provide some additional information?
- You mention that the error still exists, could you please clarify which specific error you are encountering? Are you referring to the connection dropping while roaming, or is it the connection dropping when switching the security mode setting from 'WPA3 Mix' to 'WPA2', necessitating you to set up the network again?
- To better understand the situation, could you please provide us with the device model and the OS version you're using on your smartphone (both Apple and Android)?
Looking forward to your response so we can resolve this issue together.
Kay
I have connection problem with different phones. They disconnect and unable to reconnect and fail with wrong password.
- IPhone 11, iOS 17.4.1
- IPhone 12, iOS 17.4.1
- iPhone 13, iOS 16.0
I use firmware V1.0.0(ABZF.6)C0 (latest)
Please help!
Hi @freddy75
Thanks for the feedback
We have received your send feedback.We will contact you via email.
Best Regards,
Jerry0
- 397 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 5.1K Security
- 91 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 918 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 211 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2K FAQ
- 920 Nebula FAQ
- 422 Security FAQ
- 237 Switch FAQ
- 208 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 139 Service & License FAQ
- 72 About Community
- 62 Security Highlight
