NAS326
  • suisei
    suisei Posts: 120 image  Ally Member
    First Comment First Answer Friend Collector Second Anniversary
    Is the NAS being utilized as a server? I suggest placing it behind a firewall/router for enhanced security. And do the test in the lab.
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    It's Possible this resoult?
    It's not clear to me what you have done. The URL leads to an in-browser speed test, but your screenshot suggests a commandline action.
    I wouldn't know why 500Mbps should be a problem. When I remember well ZyXEL specified a disk access speed of ~70MB/sec over the network. That is around 700Mbps, and then the disks are in action as well.
  • Carna75
    Carna75 Posts: 1
    edited April 2024
    Scusate se mi intrometto … Io ho installato un secondo disco di archiviazione pero non riesco ad accedervi per salvare dati …mi dice che il volume 1 sta utilizzando il 100%dello spazio , si prega di aprire lo storage manager espandere la capacità di archiviazione…. come si fa ?
    Grazie anticipatamente
