NR7101 loosing LAN connection
i got an big problem with 2 zyxel NR7101,
It allays loosing connection to the LAN networks after some hours, sometime days, randomly
It only can be resolved by reset to default and reenter all data, then it works for some time
the WAN connection of the router will still work, but it will not send any data to the LAN
Also the ARP table of the IP4 protocols are near empty
I got exactly 2 units with same problem
I have allready the newest firmware on it, from telekom
It have an DHCP server on Bridge 1 running and an Zyxel WAC6552D behind
the system runs before for years without problems
I also got an fixed IP from my provider now,
But i think its an Communication problem with the LAN
Und the WAC hotspot are only connected 5 arlo webcams
Any network switches in-between that could be causing issues or any old/damaged ethernet cables? Are you more than 100m away from the NR7101? How old are the NR7101 units as sometimes a failing PoE injector could cause weird issues.
PoE injector was allready change and the WAC6552 connected direct on the NR7101
Now i use an different LAN dhcp range, at its still online since 2 day, will see it works1 -
worked 2 weeks now,
Now same problem again 🤬
i can access the router over the internet and LAN, but it will not transfer data to next WLAN-Accesspoint WAC6552D, no trafic shows in ARP table to LAN-IP4
reset to default works for few days, then same issue, tryed different 7101, allways same problems
this looks like firmware issue
now i have ordered an 7201 and an DLINK 5G router as replacement0 -
hi yah, I am getting this issue as well and can not find a way to resolve it. Did the 7021 resolve the issue
- 434 Beta Program
- 174 Nebula Ideas
- 418 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 270 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 87 Security Highlight
