Any issues w Nebula access r.n.?
Patrik63
Patrik63 Posts: 5 image  Freshman Member
App says "unable to resolve host nebula.zyxel.com…
    PeterUK Posts: 4,169 image  Guru Member
    DNS servers go wrong sometimes like for me I run my own bind DNS and found it didn't forward nebula.zyxel.com IP's to client it was getting the answer but not replying to the client a restart of bind fixed it but I'm not sure why….
    try changing to like 1.1.1.1, 8.8.8.8 or 9.9.9.9
  • Zyxel_Kay
    Zyxel_Kay Posts: 1,279 image  Guru Member
    edited May 2024 Answer ✓
    Hi @Patrik63
    We are currently experiencing a service issue affecting certain areas. As a workaround, please try changing your device’s DNS server to 8.8.8.8. For more detailed information, please refer to this post:
    Thank you for your understanding.
    Kay
Nebula Tips & Tricks
