NR5101 logging to local file produces no entries
NR5101 with latest firmware. Enabled syslog in Maintenance → Log Setting, mode "Local File" and enabled everything under "Active Log", but I never see anything in System Monitor → Log. Tried refreshing, exporting log. It's been running like this for a few days without producing a single message, despite definitely log-worthy things like restarts and DHCP renewals with IP changes happening.
  • adogontheinternet
    Downgrading the firmware from V1.00(ABVC.9)D0 to V1.00(ABVC.6)C1 got the logging working. (Thanks to user Noddy for help on this.)
  • Termidk
    Termidk Posts: 7
    image  Freshman Member
    I have exactly the same experience with no logging on the same router
  • adogontheinternet
