How to remove device from portal.myzyxel.com?
ermesinformaticasrl
ermesinformaticasrl Posts: 1  Freshman Member
First Anniversary
I have an access point in the list of devices that I need to remove in order to register it on another account.
You can help me?
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,317  Zyxel Employee
    Hi @ermesinformaticasrl ,
    If you want to remove an access point to register it under a different account and manage it via Nebula, follow these steps:
    • Download the Nebula Mobile App and log in with the account you want to use.
    • Select the Organization and Site where you want to register the access point.
    • Scan the QR Code on the access point using the app.
    For a detailed guide, refer to this link
    Zyxel_Judy
    Untitled Image
  • Zyxel_Judy
    Zyxel_Judy
    Untitled Image
Nebula Tips & Tricks
