LTE7490-M904 stuck in Bridge mode
Hi, I have a brand new LTE7490-M904. I packed it up and tested it for a customer and it worked perfect. The only thing I changed was the password, nothing else.
I went out to the costumer and installed it. Here comes the strange thing - Bridge mode. The machine acts as beeing in bridge mode and I can´t change it! If I go to Network settings, Brodband I see four Cellular WAN (1,2,3,4) and it seems correct (type:cell, Mode:Routing). If I click Modify on WAN1 there is nothing I can do! I should be able to alter bridge/router mode but there is no "Mode row" and it acts like in bridge mode, one public IPv4 address in to my computer.
Updateing the firmware or resetting to factory default (both in software and the button) make no change. And, yes, I used the same SIM card all the time. The signal is good, 75-90%.
Please help - what should I do?
Sorry about bad english, hope you understand,
Håkan
Cellular APN / Modify / Turn Off IP Passthrough / OK.
You may need to reboot (not factory reset).
Hello Selberg, thanks. This solwed the problem. There are many other funny things but this is good for now.
Håkan
In router mode (ip passthrough DISABLED), is it possible to destroy bridge1 (grouping interface section) ?
I disabled IP Passthrough, but I continue to see spoofing packets on my firewall wan interface (which is connected to the LTE7490). These packets comes from IP of LTE interface (CGNAT) or the LAN ip interface of the LTE7490.
- 441 Beta Program
- 529 USG FLEX H Series
- 333 Security Ideas
- 51 Wireless Ideas
- 292 Service & License
- 461 News and Release
