How can I access NAS326 from Windows after the latest update?
jaron
jaron Posts: 1 image  Freshman Member
 It shows only up as a media device.
  • soul
    soul Posts: 29 image  Freshman Member
    You can map your NAS to a network drive.
    Go to This PC > at the upper left click on Map network drive > Choose Drive and type
    "\\IP_Address_of_NAS\admin"  into textbox without quotation marks.
    Click on both checkboxes. Then click on Finish.
    This will map a virtual drive to your NAS device.
  • VooDoo
    VooDoo Posts: 1
    edited June 2024
    After reinstalling and reformatting the Windows 10, I am struggling with mapping my drives. So far enabling SMBv1 protocol helped to make it at least visible. But I still need to figure out how to fix this issue.
  • Mijzelf
    Mijzelf Posts: 3,049 image  Guru Member
    The error message is clear, although unexpected. For some reason your Windows system doesn't allow access to a guest account on a remote system. Apart from the arrogance of that, apparently you are logging in as guest on your NAS. Maybe it helps to explicitly specify a user using the 'connect using different credentials' option.
