How can I access NAS326 from Windows after the latest update?
jaron
It shows only up as a media device.
You can map your NAS to a network drive.
Go to This PC > at the upper left click on Map network drive > Choose Drive and type
"\\IP_Address_of_NAS\admin" into textbox without quotation marks.
Click on both checkboxes. Then click on Finish.
This will map a virtual drive to your NAS device.
After reinstalling and reformatting the Windows 10, I am struggling with mapping my drives. So far enabling SMBv1 protocol helped to make it at least visible. But I still need to figure out how to fix this issue.
The error message is clear, although unexpected. For some reason your Windows system doesn't allow access to a guest account on a remote system. Apart from the arrogance of that, apparently you are logging in as guest on your NAS. Maybe it helps to explicitly specify a user using the 'connect using different credentials' option.
- 237 Nebula Ideas
- 6.8K Security
- 740 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
