NR5101 - IP Passthrough Mode disabled
Hi @GiuseppeR ,
To check the issue with your site, please help to enable Zyxel support.
Additionally, provide us with the name of your Nebula organization/site here or via the private message by clinking to my account > Message.
Zyxel_Judy
Hi @GiuseppeR ,
At the time of this writing, the specifications for the indoor mobile router, including the NR5101, are as follows:
- When IP passthrough mode is enabled, the Ethernet WAN tab disappears.
- Similarly, when Ethernet WAN (port LAN1 becomes the WAN port) is enabled, the IP passthrough mode tab disappears. It means if you use the Ethernet WAN, the NR5101 will be in Router mode.
Zyxel_Judy
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
