Zyxel NR 2301 Zyxel Air Login Problem
I am able to login to my Zyxel NR 2301 with the admin user from my PC and from my mobile phone. But when I want to login with Zyxel Air on my mobile phone then (after I have entered the user name and password) the login doesn't continue at the step "Logging in the Zyxel Router". What could be the reason for this?
OS: Android 14
Zyxel Air V. 1.2.2.240123
Zyxel NR 2301 FW V1.00(ACIY 3)C0
Knowbody is able to help?
I own a NR7101.
I connect Air app through my mesh system but i can't connect only type in admin and password.
I need to go to advanced settings and fill in.....
B.T.W. My mesh use 192.168.1.1, that's why i use 192.168.2.1.
Thanks for your reply. I tried the advanced settings before but with the HTTPS Port being empty. I now filled 443 but it still doesn't work. I'm using the below settings. 192.168.1.1 doesn't conflict with my FritzBox which is using 192.168.178.1.
I also switch off my VPN (as otherwise it won't show the login dialog when using the browser login).
Ever tried empty air app cache, i have had som issues with that.
If not still working, uninstall app, restart phone and reinstall it.
Unfortunately even after uninstalling the app, restarting the phone and reinstalling the app, the situation remains the same.
- 603 USG FLEX H Series
- 481 News and Release
