Firmware updated but unable to login
13
  • Peter2
    Peter2 Posts: 131  Ally Member
    5 Answers First Comment Friend Collector Community MVP
    I think you cannot upgrade firmware from stock to original-CO in the regular way over web gui ?
    So you made something special and harmed the device ?
  • bulldog715
    bulldog715 Posts: 29  Freshman Member
    I almost nearly there!!!!
    Microsoft Windows [Version 10.0.22631.3810]
    (c) Microsoft Corporation. All rights reserved.
    C:\Users\pc>ftp 192.168.1.1
    Connected to 192.168.1.1.
    220---------- Welcome to Pure-FTPd [privsep] ----------
    220-You are user number 1 of 50 allowed.
    220-Local time is now 00:43. Server port: 21.
    220-IPv6 connections are also welcome on this server.
    220 You will be disconnected after 15 minutes of inactivity.
    504 Unknown command
    User (192.168.1.1:(none)): admin
    331 User admin OK. Password required
    Password:
    230 OK. Current restricted directory is /
    ftp> bin
    200 TYPE is now 8-bit binary
    ftp> put C:\Users\pc\Desktop\V517ABMT6C0.bin
    200 PORT command successful
    553 Can't open that file: Permission denied
    ftp>
    Why it can't open that file: Permission denied?
  • Peter2
    "Why it can't open that file: Permission denied?"
    try put the file direct to main directory C:\ ….
  • bulldog715
    Still the same Permission denied
    Grrrr
  • bulldog715
    I think it stupid Windows 11 won't let me (still Permission denied) I will try later on Linux
  • Peter2
    May be controlling your PC firewall if Port 21 is open ?
  • bulldog715
    How to do that in pc firewall (port 21 open) is there any other way to do in Linux terminal instead?
  • Peter2
    edited July 1
    Begin before ftp login in the windows terminal cmd line and change the directory to main directory "cd /" where the firmware file is to be found.
    You see it in the Terminal prompt which is the current .
    And then login over ftp and try again .
    If you have a ftp login try first and type in "ls" and you can see if data connection is accepted .
  • bulldog715
    C:\Users\pc>cd /
    C:>ftp 192.168.1.1
    220-Local time is now 00:16. Server port: 21.
    504 Unknown command
    Password:
    ftp> bin
    ftp> put C:\V517ABMT6C0.bin
  • Peter2
    What happens when you put in the command "ls" do you have a successfull data connection ?
