NSA325v2 - Entware-ng - SAMBA - no samba after hot NAS restart
Ok, another finding and it seems to be related to entware-ng.
in the post above I told that newly created shares are not visible via FTP, but visible via SMB.
so I disabled entware-ng and connected via WinSCP via FTP. voila! I can see all shares including new ones:
and File Browser now displays everything as expected
Regards, -A
and then I did another test
- i disabled entware-ng
- i created a new share "testsharewithoutentwarengenabled" in the hope that may be it would be visible via FTP if created when entware-ng is disabled
- i checked with disabled entware-ng via FTP - the share was visible
- as soon as I enable entware-ng FTP does not show shares I created recently
so again I am not blaming SambaReplacement and my issue might be very unique to my screwed up configuration or a very old NAS325v2, but anyway this is an interesting finding.
what I would recommend to anyone is doing "Configuration Backup" as often as possible, because in my case it was part of a remedy. another part of a remedy was to manually remove two pid files blocking start of SAMBA in /opt/var/run as Mijzelf suggested
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
