Firmware updated but unable to login
I think you cannot upgrade firmware from stock to original-CO in the regular way over web gui ?
So you made something special and harmed the device ?
I almost nearly there!!!!
Microsoft Windows [Version 10.0.22631.3810]
(c) Microsoft Corporation. All rights reserved.C:\Users\pc>ftp 192.168.1.1
Connected to 192.168.1.1.
220---------- Welcome to Pure-FTPd [privsep] ----------
220-You are user number 1 of 50 allowed.
220-Local time is now 00:43. Server port: 21.
220-IPv6 connections are also welcome on this server.
220 You will be disconnected after 15 minutes of inactivity.
504 Unknown command
User (192.168.1.1:(none)): admin
331 User admin OK. Password required
Password:230 OK. Current restricted directory is /
ftp> bin
200 TYPE is now 8-bit binary
ftp> put C:\Users\pc\Desktop\V517ABMT6C0.bin
200 PORT command successful
553 Can't open that file: Permission denied
ftp>Why it can't open that file: Permission denied?
"Why it can't open that file: Permission denied?"
try put the file direct to main directory C:\ ….
Still the same Permission denied
Grrrr
I think it stupid Windows 11 won't let me (still Permission denied) I will try later on Linux
May be controlling your PC firewall if Port 21 is open ?
How to do that in pc firewall (port 21 open) is there any other way to do in Linux terminal instead?
Begin before ftp login in the windows terminal cmd line and change the directory to main directory "cd /" where the firmware file is to be found.
You see it in the Terminal prompt which is the current .
And then login over ftp and try again .
If you have a ftp login try first and type in "ls" and you can see if data connection is accepted .
C:\Users\pc>cd /
C:>ftp 192.168.1.1
220-Local time is now 00:16. Server port: 21.
504 Unknown command
ftp> bin
ftp> put C:\V517ABMT6C0.bin
553 Can't open that file: Permission denied0 -
What happens when you put in the command "ls" do you have a successfull data connection ?
- 435 Beta Program
- 176 Nebula Ideas
- 425 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
