How to get rsync work on NAS326
anmi4345
anmi4345 Posts: 9  Freshman Member
First Comment Seventh Anniversary
What I did:
renewed web_prefix (for MetaRepository)
installed MR, changed to new Mijzelf Repo (zyxel.diskstation.eu/..)
updated apps
installed RandomTools, but not visible.
Downloaded libiconv and unpacked and copied to /i-data/sysvol/.PKG/RandomTools/lib/
did not work, too.
Can somebody help, please and advice?
  • Mijzelf
    Mijzelf Posts: 2,957  Guru Member
    RandomTools is a collection of commandline tools, and has no webinterface. You can en- or disable them, that's all.
  • Mijzelf
    rsync is in RandomTools, but it doesn't have a web interface. If you want to run an rsync client, just login over ssh, and run 'rsync [args]' like always.
    For running an rsync daemon you'll have to provide a configuration file, which describes shared directories and credentials.
    To get the daemon started on boot you can use the init.d directory in the RandomTools package, which RandomTools uses to 'inject itself', but it will also start custom scripts.
  • anmi4345
    My problem is: I dont get RandomTools to start. It is installed, but I have no chance in activate some Tools.
    Also the Icon is missing on Desktop.
  • Mijzelf
