NR5101 NAT not working
francisp
francisp Posts: 2
edited July 2024 in Mobile Broadband
I have a NR5101, Latest firmware, V1.00(ABVC.9)C0
I can access the internet without problem.
When I set a port forwarding (NAT) toward my LAN-ASUS it is not working. The same configuration is working OK with my old router.
Port Forwarding : Active
Service name : gara1
Start Port : 99
End Port : 99
Translation start port : 99
Translation end port : 99
Server IP address > 192.168.3.xxx (my ASUS)
Protocol : TCP/UDP
Custom port test with https://www.whatsmyip.org/port-scanner/ reports TimeOut
I am obviously missing something…
Any help?
  • francisp
    francisp Posts: 2
    Thank you very much for coming back.
    In fact I have just found where the problem is; my provider is blocking the NAT TCP/UDP access.
    Time to find another one ;-)
    best
    francis
  • Bob_C
    Bob_C Posts: 222 image  Master Member
    Hi francisp,
    Can you please check your WAN IP address?
    Is it a private address, e.g. 10.0.0.0 - 10.255.255.255, or 172.16.0.0 - 172.31.255.255 or 100.64.0.0 - 100.127.255.255?
    Regards,
    Bob
  • francisp
    francisp Posts: 2
    best
    francis
