NR5101 NAT not working
I have a NR5101, Latest firmware, V1.00(ABVC.9)C0
I can access the internet without problem.
When I set a port forwarding (NAT) toward my LAN-ASUS it is not working. The same configuration is working OK with my old router.
Port Forwarding : Active
Service name : gara1
Start Port : 99
End Port : 99
Translation start port : 99
Translation end port : 99
Server IP address > 192.168.3.xxx (my ASUS)
Protocol : TCP/UDP
Custom port test with reports TimeOut
I am obviously missing something…
Any help?
Thank you very much for coming back.
In fact I have just found where the problem is; my provider is blocking the NAT TCP/UDP access.
Time to find another one ;-)
best
francis
Hi francisp,
Can you please check your WAN IP address?
Is it a private address, e.g. 10.0.0.0 - 10.255.255.255, or 172.16.0.0 - 172.31.255.255 or 100.64.0.0 - 100.127.255.255?
Regards,
Bob
best
francis
- 603 USG FLEX H Series
- 480 News and Release
