Unable to register my device
jj_1122
jj_1122 Posts: 4  Freshman Member
edited July 2024 in Nebula
I am trying to register my new Zyxel FWA510 router under the device registration option on the site
https://portal.myzyxel.com/my/devices/link
I am seeing following error.
portal.myzyxel.com says
Cannot find device.
  • tonygibbs16
    tonygibbs16 Posts: 977  Guru Member
    edited July 2024
    Hello @jj_1122
    Welcome to the forum.
    I don't know if the Zyxel registration was affected yesterday by the Microsoft/Crowdstrike issue or not.
    • The issue happened globally yesterday.
    You might want to try again to see if it works today or tomorrow.
    Kind regards Tony
  • Zyxel_Judy
    Zyxel_Judy Posts: 2,204  Zyxel Employee
    Hi @jj_1122 ,
    Have you successfully registered the FWA510 today?
    If not, please provide the MAC address and serial number via private message by clicking on my account > Message. We'll check and inform you of any findings.
  • jj_1122
    Hello, Thanks for your replies.
    I am not able to register the device on the following portal.
    https: // portal.myzyxel.com /my/ devices /link
    However, I could register the device on
    https: // nebula.zyxel.com
    I am not sure now whether that device really intended to be registered on the first portal.
    Also, It has been 10 days since I received this device from Amazon and it has started making a hissing sound. I believe it is a fan which keeps running. This is fairly noticeable or audible during nighttime. A restart is all it needs. After the restart the device is dead silent but after running for a few hours, the sound is back. I am thinking of returning this and getting another one.
    Kind regards.
  • Zyxel_Judy
    Hi @jj_1122 ,
    We found that your FWA510 is in the Nebula's jagdish_org organization and is registered on the https://portal.myzyxel.com/ already.
    You can follow the hissing sound issue at this post:
    Zyxel FWA510 fan making consistent noise — Zyxel Community
Nebula Tips & Tricks
