Nebula not able to log in. Logout automatically
I try to log in to nebula cloud. After login nebula logouts me automatically and redirects to login website. I tried log in on mobile phone, pc etc. and everywhere result is the same.
If I try log in to „my zyxel” everything works fine, but if I try to nebula cloud I cannot.
Hi @Michau_uu
As discussed in our private message, there was an issue with your account. We have recovered the account from our backend system. Please log in to your Nebula CC account again and check if the issue is resolved.
We apologize for any inconvenience caused and thank you for your patience.
Kay
Hi @Michau_uu
Since the launch of Zyxel Account 3.0, we support various login methods, such as Email, Google, or Apple login. Please ensure you are using the correct login method.
To better understand your issue, could you please provide a screen recording of the problem and share it with us via private message? If you're using a PC, you can use this tool:
.Thank you!
Kay
My account is connected with my google account.
I sent you private message.
Michal0 -
Hi @Michau_uu
Kay
- 434 Beta Program
- 2.6K Nebula
- 170 Nebula Ideas
- 400 USG FLEX H Series
- 296 Security Ideas
- 1.5K Switch
- 43 Wireless Ideas
- 267 Service & License
- 412 News and Release
- 87 Security Advisories
- 4K FAQ
- 83 Security Highlight
