NWA130BE Lan Port for VLAN 2
Best Answers
Change PVID to "2" in your case - that should work.
Hi @George993 ,
If your access point supports a LAN port, it will be listed at the bottom of the page.
To change the LAN port settings of a specific AP, click on that AP and configure the settings.
Zyxel_Judy
Thanks David. I use Nebula and found it as well in the AP and Port settings. Good to know where I can change it as well if I decide not to renew Nebula. I assume you have to change it for every AP when web managed? I wish there was a way in Nebula to apply it only to one AP, it changes all of them.
George
Hi @George993 ,
Zyxel_Judy
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
