NAS542 Can't find NAS on the network after shutdown/reboot, not even after reset
I have a NAS542 (for some years now) and haven't upgraded to the latest latest firmware (without access to the NAS I don't remember what version is was), I know it's loaded with the version exactly before the last one.
After some hard shutdowns using the button (that's how my kid learned to shut it off….) when booting the NAS, the disks were spinning and the lights blinking for some time, but that's it. At one point they stop. I can't find my NAS on the network (with its IP or domain name) and can't connect with ssh to it (I get a timeout).
After some time and futile efforts, I reset the NAS using the button on the back of the device (pushed the button until I heard the second beep, released then heard 3 beeps). The NAS is unreachable through the network, still. No web UI at http://nas542, nothing in its old IP, nothing on the network looking at the router's page…….
I'm at a loss, I don't know what to do… I actually ordered a second one, in the hopes I can just physically move the disks from this one to the other one, but I don't even remember what RAID setting I had (IIRC, it was one where I was using all available space except one disk, i.e. 1/4th of the space was used for RAID checksums, and I could lose/replace up to one disk without data corruption)
Best Answers
Have you tried:
- another cable
- another switch port
- another network port on the NAS?
That is raid5.
When you ordered another NAS540 or NAS542 (are they still for sale?) they should accept the disks as-is. You only have to create users and groups, and (re-)enable the shares. That information is not stored on the disks, but on a flash partition in the NAS.
Tried another cable………… and yes….. now I see it, duh!! It's indeed raid 5.
I ordered the last NAS542 I found on the local market, it was pretty cheap. I won't cancel the order after this, I'll actually build a backup (should have done that a long time now). Good to know that being the same it should accept the disks as-is (I will try it out and confirm here).Really appreciate the swift reply btw, thanks!
Have you tried:
- another cable
That is raid5.
- 603 USG FLEX H Series
- 480 News and Release
