LTE7490M904 Outside Router
Hi, I have the above it has firmware 1.00(ABQY.2)C0 I would like to update to the latest firmware I unzip the file and put it in the router press update then all I get is image uploading failed, what am I doing wrong ?
Thanks for any replies
Only put bin-file there and upload.
hi, that’s what I do but it says image uploading failed, I am using a iPad Pro to perform this
Thanks.
Try without sim!
no just the same, I even factory reset then tried to update - no joy
The reason I want to update is because about once a week or so the router slows down the mbs I typically get around 130mbs but router slows to 50 or 60 until I reboot it then it’s back to normal.
Thanks.
Open link and scroll down to 7490.
Try upgrade from 2-4, 4-5 and so on.
Also check modem code file if you have the latest.
Still no joy. Sorry but where is the modem code file?
I think I should tell you I am not very tech with this sort of stuff
Direct link(from link above) for mode firmware:
https://www.dropbox.com/s/knahqrugfmha9p3/Update_EG18EAPAR01A07-R01A08.zip?dl=1
- 439 Beta Program
- 2.8K Nebula
- 199 Nebula Ideas
- 6.3K Security
- 485 USG FLEX H Series
- 320 Security Ideas
- 83 Switch Ideas
- 46 Wireless Ideas
- 284 Service & License
- 451 News and Release
- 4.3K FAQ
- 93 Security Highlight
