ZyWALL 310 unexpected reboot
XStead
XStead Posts: 7  Freshman Member
edited April 2021 in Security
We have problem with our ZyWALL 310 ... started since last week ...
Our device rebooting in every 3 days, we cannot find any info in the log files, now trying to save log to USB drive...
ZyWALL 310
firmware: V4.31(AAAB.0) / 2018-03-27 17:03:23
without UTM service
Does anyone having the same issue?
«13456
  • Zyxel_Emily
    Zyxel_Emily Posts: 1,431  Zyxel Employee
    About reboot issue, we need more information to help you on this case.
    I will send you private message for some basic information of this issue.
  • alexey
    alexey Posts: 188  Master Member
    Yes, 2 diff USG 1100 start rebooting in last 10 days. Now disable AV, maybe rebooting stops.Third USG 1100 in another area without internet works normal.
  • jonatan
    jonatan Posts: 198  Master Member
    I have a few ZyWALL 310, this problem is not observed.
  • XStead
    After 22 days it rebooted again... we are unhappy :(
    Log contains etc..:
    - NMI Watchdog interrupt on Core 0x00
    *** Chip soft reset soon ***
    Output the command:
    "Router> show software-watchdog-timer log"
    - Reason: Software Watchdog Reboot System
    - Reason: Fatal Error Cause System Reboot
    - CPU 0 Unable to handle kernel paging request at virtual address 0000000000000044
    etc..
    We are waiting the resolution...
  • alexey
    I confirm.
    After 2 weeks, 05/11/2018 was 2 unexpected reboots. Was holiday, can't collect logs via console.
    Now connect and wait.
  • Zyxel_Emily
    We receive your console logs in the private message.
    We will analyze the logs and update the progress to you.
  • alexey
    Today it reboots again.
    I send you log in private message.
  • Zyxel_Emily
    Thanks for the console logs.
    We will analyze the logs and update the status to you.
  • XStead
    Did you resolve the problem ?
    Our zywall still restart itself randomly...
    I've sent the logs in private
