Recycle Bin does not work when deleting from SMB
Verz
Hi, my Zyxel Nas 326 do not move files into the recycle folders when I access it through SMB via my Linux machine. On the serve is running an instance of Nextcloud.
Instead, if I delete them via my SMB application on my phone they are correctly moved into the recycle folders.
Could you help me?
Thank you
Solved, it was an issue with my Nextcloud. Configured the config.php file to define the retention date
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
