NWA50AX PRO 160mhz
Hi @rossano,
Thanks for the information! We will check it and update you once I have further information.
Zyxel Melen0 -
Thank you, let me know if you need anything else.
Hi @rossano,
After checking, your AP didn't keep in 160 MHz because the AP detects radar. Once radar is detected, the AP must change to 80MHz to avoid radar channel because the original service channel can’t be used per regulatory requirements.
If there are often radar signals in the environment, switching to another channel and using it at 160MHz will not be implemented forever, because the radar channel will still be covered. AP will switch to a non-DFS channel and remain there for 30 minutes.
If no radar is detected within that timeframe, the AP will resume using the DFS channel and potentially return to 160MHz bandwidth. However, if radar is still detected after 30 minutes, the AP will stay on the non-DFS channel, with the maximum channel width is 80 MHz.
For more information, please reference this FAQ:
How does a Zyxel AP behave when encountering radar? — Zyxel Community
Zyxel Melen0 -
In the log the AP is changing channel from 116 to 36. But I had the fixed channel on 48. Now I switched on fixed 36. I will check if this happens again. Maybe is because the 160 MHz is so wide that goes in a DFS channel?
Hi @rossano,
Apologize for the delay.
Yes, that is the reason. Please reference the screenshot below to find the related channels for each channelwidth.
Zyxel Melen0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
